CorporalStorm
- Sep 21, 2005
Ok.. I just ran across some funny things... I did some research into the C5 case and modding it is very limited.. Due to the construction of the case. For instance you cannot cut out the metal infront of the front 80mm fan due to the I/O Ports and Power Switches mounting there. So I have an idea.. At the moment I have upgraded fans in the case (Blue LEDs).
What I'm thinking of doing is this, I found the Scythe Kama Bay that mount into 2 5.25" bay slots with a 120mm Fan. I have 4 slots out of the 5 free. I dont use anything else but a CDRom. I was thinking about buying two of the bay mounts and upgrading the fans to 2k RPM fans and putting them behind the bay covers. The entire front of the C5 is black metal mesh with filters so airflow can go through. My question should I do it? and if I do should I put in Blue LED Fans or just black. Would it be overkill having blue glowing up that high?
Storm
Storm
