centronics diagram
lukeh182
can anyone tell me or direct me to a place where i can find a diagram for a 36 pin centronics connection? i need to know what color wire goes to which pin.
btw: i tried to do a google but couldn't find what i wanted.
Originally posted by lukeh182
thanks BUT i need to know the COLORS
If you can't take the connector at the other side apart, or if you're certain that a standard wiring is used in the aforementioned connector, but don't have an old, wired up Centronics connector lying around, you can just perform a continuity check with a DMM.
