D
Deleted member 88227
Guest
EXT64 Come help me lol
[boinc@BOINC boinc_source]$ ./configure --disable-server --enable-optimize
checking build system type... x86_64-unknown-linux-gnu
checking host system type... x86_64-unknown-linux-gnu
checking target system type... x86_64-unknown-linux-gnu
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /usr/bin/mkdir -p
checking for gawk... /usr/bin/gawk
checking whether make sets $(MAKE)... yes
checking whether make supports nested variables... yes
checking whether make supports nested variables... (cached) yes
checking for gcc... gcc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking for style of include used by make... GNU
checking dependency style of gcc... gcc3
checking for g++... /usr/bin/g++
checking whether we are using the GNU C++ compiler... yes
checking whether /usr/bin/g++ accepts -g... yes
checking dependency style of /usr/bin/g++... gcc3
checking whether we are using the GNU Objective C++ compiler... no
checking whether /usr/bin/g++ accepts -g... no
checking for g77... no
checking for xlf... no
checking for f77... no
checking for frt... no
checking for pgf77... no
checking for cf77... no
checking for fort77... no
checking for fl32... no
checking for af77... no
checking for xlf90... no
checking for f90... no
checking for pgf90... no
checking for pghpf... no
checking for epcf90... no
checking for gfortran... /usr/bin/gfortran
checking whether we are using the GNU Fortran 77 compiler... yes
checking whether /usr/bin/gfortran accepts -g... yes
checking how to run the C preprocessor... gcc -E
checking whether make sets $(MAKE)... (cached) yes
checking for ln... /usr/bin/ln
checking whether '/usr/bin/ln' works... yes
/bin/rmdir: failed to remove 'ln_test': No such file or directory
checking whether ln -s works... yes
checking whether 'ln -s' really works or whether I'm deluding myself... it works
checking whether gcc and cc understand -c and -o together... yes
checking if C compiler supports -Wall... yes
checking if C++ compiler supports -Wall... yes
checking if f77 compiler supports -Wall... yes
checking if C compiler supports -ffast-math... yes
checking if C compiler supports -O3... yes
checking if C++ compiler supports -ffast-math... yes
checking if C++ compiler supports -O3... yes
checking if f77 compiler supports -ffast-math... yes
checking if f77 compiler supports -O3... yes
--- Configuring BOINC 7.11.0 (Release) ---
--- Build Components: (client manager libraries) ---
checking for docbook2x-man... no
checking for grep that handles long lines and -e... /usr/bin/grep
checking for egrep... /usr/bin/grep -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking whether we are compiling for cygwin... no
checking for winsock2.h... (cached) no
checking for winsock.h... (cached) no
checking windows.h usability... no
checking windows.h presence... no
checking for windows.h... no
checking sys/socket.h usability... yes
checking sys/socket.h presence... yes
checking for sys/socket.h... yes
checking how to print strings... printf
checking for a sed that does not truncate output... /usr/bin/sed
checking for fgrep... /usr/bin/grep -F
checking for ld used by gcc... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking for BSD- or MS-compatible name lister (nm)... /usr/bin/nm -B
checking the name lister (/usr/bin/nm -B) interface... BSD nm
checking the maximum length of command line arguments... 1572864
checking whether the shell understands some XSI constructs... yes
checking whether the shell understands "+="... yes
checking how to convert x86_64-unknown-linux-gnu file names to x86_64-unknown-linux-gnu format... func_convert_file_noop
checking how to convert x86_64-unknown-linux-gnu file names to toolchain format... func_convert_file_noop
checking for /usr/bin/ld option to reload object files... -r
checking for objdump... objdump
checking how to recognize dependent libraries... pass_all
checking for dlltool... dlltool
checking how to associate runtime and link libraries... printf %s\n
checking for ar... /usr/bin/ar
checking for archiver File support... @
checking for strip... strip
checking for ranlib... ranlib
checking command to parse /usr/bin/nm -B output from gcc object... ok
checking for sysroot... no
checking for mt... no
checking if : is a manifest tool... no
checking for dlfcn.h... yes
checking for objdir... .libs
checking if gcc supports -fno-rtti -fno-exceptions... no
checking for gcc option to produce PIC... -fPIC -DPIC
checking if gcc PIC flag -fPIC -DPIC works... yes
checking if gcc static flag -static works... no
checking if gcc supports -c -o file.o... yes
checking if gcc supports -c -o file.o... (cached) yes
checking whether the gcc linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
checking whether -lc should be explicitly linked in... no
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking for shl_load... no
checking for shl_load in -ldld... no
checking for dlopen... no
checking for dlopen in -ldl... yes
checking whether a program can dlopen itself... yes
checking whether a statically linked program can dlopen itself... yes
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... yes
checking how to run the C++ preprocessor... /usr/bin/g++ -E
checking for ld used by /usr/bin/g++... /usr/bin/ld -m elf_x86_64
checking if the linker (/usr/bin/ld -m elf_x86_64) is GNU ld... yes
checking whether the /usr/bin/g++ linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
checking for /usr/bin/g++ option to produce PIC... -fPIC -DPIC
checking if /usr/bin/g++ PIC flag -fPIC -DPIC works... yes
checking if /usr/bin/g++ static flag -static works... no
checking if /usr/bin/g++ supports -c -o file.o... yes
checking if /usr/bin/g++ supports -c -o file.o... (cached) yes
checking dynamic linker characteristics... (cached) GNU/Linux ld.so
checking for /usr/bin/gfortran option to produce PIC... -fPIC
checking if /usr/bin/gfortran PIC flag -fPIC works... yes
checking if /usr/bin/gfortran static flag -static works... no
checking if /usr/bin/gfortran supports -c -o file.o... yes
checking if /usr/bin/gfortran supports -c -o file.o... (cached) yes
checking whether the /usr/bin/gfortran linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
checking default bitness of compiler... 64
checking boinc platform... x86_64-pc-linux-gnu
checking alternate boinc platform... i686-pc-linux-gnu
checking library extension... a
checking shared object extension... so
checking for pkg-config... /usr/bin/pkg-config
checking for openssl... yes
OpenSSL found in /usr
checking for gawk... (cached) /usr/bin/gawk
checking for curl-config... /usr/bin/curl-config
checking for the version of libcurl... 7.29.0
checking for libcurl >= version 7.17.1... yes
checking whether libcurl is usable... yes
checking for curl_free... yes
checking for shmget in dynamic library cygipc... no
checking for aio_fork in dynamic library aio... no
checking for dlopen in dynamic library dl... -ldl
checking for gethostbyname in static library nsl... -lnsl
checking for static library freetype... -lfreetype
checking for bind in static library socket... no
checking for bind in dynamic library socket... no
checking for gzopen in static library z... -lz
checking for md5_finish in dynamic library cups... no
checking for the pthreads library -lpthreads... no
checking whether pthreads work without any flags... no
checking whether pthreads work with -Kthread... no
checking whether pthreads work with -kthread... no
checking for the pthreads library -llthread... no
checking whether pthreads work with -pthread... yes
checking for joinable pthread attribute... PTHREAD_CREATE_JOINABLE
checking if more special flags are required for pthreads... no
checking for PTHREAD_PRIO_INHERIT... yes
checking for X... libraries , headers
checking for gethostbyname... yes
checking for connect... yes
checking for remove... yes
checking for shmat... yes
checking for IceConnectionNumber in -lICE... yes
checking for pthread_join in LIBS= with CFLAGS=-pthread... yes
checking for PTHREAD_PRIO_INHERIT... (cached) yes
checking whether we are using the Microsoft C compiler... no
checking for windows.h... (cached) no
checking for OpenGL library... -L/usr/local/lib -lGL
checking for OpenGL Utility library... -L/usr/local/lib -lGLU
checking for fopen in -lXmu... yes
checking for fopen in -lXi... yes
checking for GLUT library... -L/usr/local/lib -lglut
checking gl.h usability... no
checking gl.h presence... no
checking for gl.h... no
checking glu.h usability... no
checking glu.h presence... no
checking for glu.h... no
checking glut.h usability... no
checking glut.h presence... no
checking for glut.h... no
checking glaux.h usability... no
checking glaux.h presence... no
checking for glaux.h... no
checking GL/gl.h usability... yes
checking GL/gl.h presence... yes
checking for GL/gl.h... yes
checking GL/glu.h usability... yes
checking GL/glu.h presence... yes
checking for GL/glu.h... yes
checking GL/glut.h usability... yes
checking GL/glut.h presence... yes
checking for GL/glut.h... yes
checking GL/glaux.h usability... no
checking GL/glaux.h presence... no
checking for GL/glaux.h... no
checking OpenGL/gl.h usability... no
checking OpenGL/gl.h presence... no
checking for OpenGL/gl.h... no
checking OpenGL/glu.h usability... no
checking OpenGL/glu.h presence... no
checking for OpenGL/glu.h... no
checking OpenGL/glut.h usability... no
checking OpenGL/glut.h presence... no
checking for OpenGL/glut.h... no
checking OpenGL/glaux.h usability... no
checking OpenGL/glaux.h presence... no
checking for OpenGL/glaux.h... no
checking GLUT/glut.h usability... no
checking GLUT/glut.h presence... no
checking for GLUT/glut.h... no
checking MesaGL/gl.h usability... no
checking MesaGL/gl.h presence... no
checking for MesaGL/gl.h... no
checking MesaGL/glu.h usability... no
checking MesaGL/glu.h presence... no
checking for MesaGL/glu.h... no
checking MesaGL/glut.h usability... no
checking MesaGL/glut.h presence... no
checking for MesaGL/glut.h... no
checking MesaGL/glaux.h usability... no
checking MesaGL/glaux.h presence... no
checking for MesaGL/glaux.h... no
checking libnotify/notify.h usability... no
checking libnotify/notify.h presence... no
checking for libnotify/notify.h... no
checking gtk/gtk.h usability... no
checking gtk/gtk.h presence... no
checking for gtk/gtk.h... no
checking for jpeg_start_compress in -ljpeg... yes
checking jpeglib.h usability... yes
checking jpeglib.h presence... yes
checking for jpeglib.h... yes
checking for XScreenSaverAllocInfo in -lXss... yes
checking X11/extensions/scrnsaver.h usability... yes
checking X11/extensions/scrnsaver.h presence... yes
checking for X11/extensions/scrnsaver.h... yes
checking for dirent.h that defines DIR... yes
checking for library containing opendir... none required
checking for ANSI C header files... (cached) yes
checking for sys/wait.h that is POSIX.1 compatible... yes
checking whether time.h and sys/time.h may both be included... yes
checking return type of signal handlers... void
checking for sys/types.h... (cached) yes
checking sys/un.h usability... yes
checking sys/un.h presence... yes
checking for sys/un.h... yes
checking arpa/inet.h usability... yes
checking arpa/inet.h presence... yes
checking for arpa/inet.h... yes
checking dirent.h usability... yes
checking dirent.h presence... yes
checking for dirent.h... yes
checking grp.h usability... yes
checking grp.h presence... yes
checking for grp.h... yes
checking fcntl.h usability... yes
checking fcntl.h presence... yes
checking for fcntl.h... yes
checking for inttypes.h... (cached) yes
checking for stdint.h... (cached) yes
checking for memory.h... (cached) yes
checking netdb.h usability... yes
checking netdb.h presence... yes
checking for netdb.h... yes
checking netinet/in.h usability... yes
checking netinet/in.h presence... yes
checking for netinet/in.h... yes
checking netinet/tcp.h usability... yes
checking netinet/tcp.h presence... yes
checking for netinet/tcp.h... yes
checking netinet/ether.h usability... yes
checking netinet/ether.h presence... yes
checking for netinet/ether.h... yes
checking net/if.h usability... yes
checking net/if.h presence... yes
checking for net/if.h... yes
checking net/if_arp.h usability... yes
checking net/if_arp.h presence... yes
checking for net/if_arp.h... yes
checking signal.h usability... yes
checking signal.h presence... yes
checking for signal.h... yes
checking for strings.h... (cached) yes
checking sys/auxv.h usability... yes
checking sys/auxv.h presence... yes
checking for sys/auxv.h... yes
checking sys/file.h usability... yes
checking sys/file.h presence... yes
checking for sys/file.h... yes
checking sys/fcntl.h usability... yes
checking sys/fcntl.h presence... yes
checking for sys/fcntl.h... yes
checking sys/ipc.h usability... yes
checking sys/ipc.h presence... yes
checking for sys/ipc.h... yes
checking sys/ioctl.h usability... yes
checking sys/ioctl.h presence... yes
checking for sys/ioctl.h... yes
checking sys/msg.h usability... yes
checking sys/msg.h presence... yes
checking for sys/msg.h... yes
checking sys/param.h usability... yes
checking sys/param.h presence... yes
checking for sys/param.h... yes
checking sys/resource.h usability... yes
checking sys/resource.h presence... yes
checking for sys/resource.h... yes
checking sys/select.h usability... yes
checking sys/select.h presence... yes
checking for sys/select.h... yes
checking sys/sem.h usability... yes
checking sys/sem.h presence... yes
checking for sys/sem.h... yes
checking sys/shm.h usability... yes
checking sys/shm.h presence... yes
checking for sys/shm.h... yes
checking sys/sockio.h usability... no
checking sys/sockio.h presence... no
checking for sys/sockio.h... no
checking for sys/socket.h... (cached) yes
checking for sys/stat.h... (cached) yes
checking sys/statvfs.h usability... yes
checking sys/statvfs.h presence... yes
checking for sys/statvfs.h... yes
checking sys/statfs.h usability... yes
checking sys/statfs.h presence... yes
checking for sys/statfs.h... yes
checking sys/systeminfo.h usability... no
checking sys/systeminfo.h presence... no
checking for sys/systeminfo.h... no
checking sys/time.h usability... yes
checking sys/time.h presence... yes
checking for sys/time.h... yes
checking sys/utsname.h usability... yes
checking sys/utsname.h presence... yes
checking for sys/utsname.h... yes
checking sys/vmmeter.h usability... no
checking sys/vmmeter.h presence... no
checking for sys/vmmeter.h... no
checking for sys/wait.h... (cached) yes
checking for unistd.h... (cached) yes
checking utmp.h usability... yes
checking utmp.h presence... yes
checking for utmp.h... yes
checking errno.h usability... yes
checking errno.h presence... yes
checking for errno.h... yes
checking procfs.h usability... no
checking procfs.h presence... no
checking for procfs.h... no
checking ieeefp.h usability... no
checking ieeefp.h presence... no
checking for ieeefp.h... no
checking setjmp.h usability... yes
checking setjmp.h presence... yes
checking for setjmp.h... yes
checking float.h usability... yes
checking float.h presence... yes
checking for float.h... yes
checking sal.h usability... no
checking sal.h presence... no
checking for sal.h... no
checking execinfo.h usability... yes
checking execinfo.h presence... yes
checking for execinfo.h... yes
checking xlocale.h usability... yes
checking xlocale.h presence... yes
