Center Channel
Ok.. I have a Yamaha RX-V520 reciever.
I also have 2 Bic Venturi DV62si bookshelves
For the rear speakers, i will use my JBL Northridge Indoor/Outdoor 6.5s... http://www.amazon.com/gp/product/B0000632G7/104-7847875-4347168?v=glance&n=172282
i also have a homemade sub box with 2 12 inch solobaric s12c subs in it.. powered by probably my NAD 2150..
http://www.scottsnyder.net/images/speakers1.jpg
http://www.scottsnyder.net/images/speakers2.jpg
so.. all i need is a center channel speaker..
should i get a bic venturi to match my fronts?
http://www.amazon.com/gp/product/B00009WBYL/ref=nosim/104-7847875-4347168?n=172282
Build a center channel?
build a center and 2 fronts and move the bics to the rear?
i like the sound of those bic speakers.. so i am inclined more to do one of the first 2 options..
i don't really want to spend much money, but i could..
so does it really matter if i match brands or not really?
does anyone know of a good deal on a center channel that would compliment what i have?
The center should be a sonic match to the fronts, so getting the manufacturer's recommended center would be your best bet.
