I am trying to build a super low budget pc. I can get a Celeron m cpu online for very cheap, the only problem is there are very few mother boards and the ones I do find are crazy expensive. Is there some sort of adapter I can use to operate the celeron on other boards (one I can buy cheap)
btw, just checking: Celeron M is better that celeron (the original) and Pentium III, right?
Because all three are in the same price range (assuming you can find them)
