celeron e1200 tj. max
joshlet
core temp displays tj. max at 85 degrees celcius. is the real tj. max 100? i remember awhile back you had to add 15 to both temps and tj. max values to get an accurate reading. anybody know the correct value?
There could be a problem with Core Temp reading the value incorrectly. The 85C and 100C values are for mobile processors. According to the data sheet (section 5.3):
The Intel® Celeron® Dual-Core processor E1000 series does not support the diode correction offset that exists on other Intel processors.
so who knows how Core Temp is choosing the displayed E1200 desktop chip value.
And see this post for how the offset is used for displaying Tj max: http://softwarecommunity.intel.com/...nk/30222546/30230975/ShowThread.aspx#30230975
