Now Im an experienced overclocker, but have run into a brick wall...
The brick wall is made of
INTEL MOTHERBOARD...
Which in turn does not allow normal overclocking so i have turned to another method.
Specifically the one listed here.
http://www.plasma-online.de/index.h...lish/upgrade/tweak/fixes/fix_p62_100_133.html
But the thing is, I have a slot 370 and not a slot1. And that guide is only for a slot1.
I was wondering if in theory it would be possible to apply the same concept of this guide to a PPGA version of that cpu?
I have also found a image of which pin needs to be blocked out, but it claims its for a slot 370 PIII, not a celeron... I was wondering if i were to block that pin also would it work?
Thank you For your time and help
