Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
ANyone know where a good TV ceiling mount ? I need one that is very adjustable both 360* and also that can be adjusted up or down several feet. This is for a small 20 inch led. Thanks
For a 20 inch monitor you could use string and metal hangers. Think of a mobile.
Seriously for that size they will all be good. I have 2 ceiling mounted tvs. One is a 65 inch plasma with a def tech speaker bar under it. That's when the weight ratings get important.
Pick one that fits your requirements and budget. In that class they should all be fine.
