CD-ROMs Do not work
Patman
I bought a new one and I still get the yellow exclaimation next to it in system properties, the motherboard slot and ide cable are good I can't figure out why it won't work. I tried enable/disable, everything.
Which component has the exclamation, the IDE Controller or the DVD/CROM Drives?
cd/dvd rom drive, i told my customer to buy a new one because the old one did that, jumpers are also set.
If you've already gone through the "let windows update this driver" bit, and it didn't work...
Pop in your Windows installation disc and run a repair. The driver for something as simple as that is already in XP, and if it's not seeing it, the something happened to it.
