Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
You are correct. They are stepper motors and require stepper controller to function. The controllers tell the motor what speed and how far to travel (RPM's). If you see a motor with more than two wires going to it, more than likely it's a stepper motor. You'd be better off using servos, if possible.
