For years, my mother had plants in the entertainment center above the stereo. She had the problem, however, of overwatering her plants just about every time. It eventually caught up with her. Twice. With two busted CD players.
I saw an opportunity. I mean, what HTPC case could possibly fit better in a home theater setup than a case intended to be part of a home theater setup? So I'm planning on building a computer (well, more like taking the guts of my current setup and sticking them) in the shell of this CD player. I'll be using a Biostar M7VIZ, Athlon XP 1800, some RAM (don't know how much yet) and a weak video card that has an S-video out connector. Add a large hard drive and DVD, and it'll be great for HT.
So I went ahead and learned a few things about how to use 3DStudio Max and took a look at how it turns out. Here are a couple renders of what it will look like with the top removed. The dark maroon is the DVD, the hard drive is hidden underneath (I was too lazy to put it in), and the thing behind the DVD drive is a small flex-ATX PSU. Everything's a tight fit--even with a small graphics card, it has to be on a riser card, and the CPU Heatsink (Zalman 3100) barely clears the cover.
There's only one question: Airflow. I'd like to have as few fans as possible, and make as few holes on the top and sides as possible.
What I'm thinking is this: make a vent right next to the CPU HS for intake. Cool air goes across the HS and out through an 80mm fan next to the DVD drive. Will this give me enough air flow? If not, what else could I do?
