CD/DVD Drive no longer recognized.
Jaero
The other day got a new computer, installed Server 2008, and made it into a nice little workstation. Where the DVD drive worked initially, now it doesn't. It shows up in the boot screen and BIOS, the computer recognizes the model, that it exists and is plugged in. But when the OS loads, nothing but the HDDs show up under My Computer. It doesn't show up in the Device Manager with or without a [!]. My computer seems about as confused as I am about this.
I tried the fix in Microsoft's knowledgebase: http://support.microsoft.com/default.aspx?scid=kb;EN-US;929461
Didn't do anything for me. There are no entries for UpperFilters or LowerFilters for the drive in the registry. There are plenty that (like in the BIOS) do specify the model of it, that it should exist, probably because it did at one point.
I am a confused panda.
Update: System specs in my sig - this is the DVD drive in question:
SONY DVD RW DW-G120A ATA Device
I don't know if this has any significance - there is one alert in the Device Manager under Storage controllers: GIGABYTE GBB36x Controller. "Windows cannot start this hardware device because its configuration information (in the registry) is incomplete or damaged. (Code 19)"
software issue (though i don't know why) have you tried booting with a cd of anykind to see if your drive hasn't slung a gut?
Driver issue. The issue was the raid controller drivers. Updated them and it worked fine. Odd. I didn't expect that to affect an optical drive, but then again, I'm a RAID virgin.
