cd/dvd catalog software? Need advice.
JeffS
Hi all,
Like many, I archive a bunch of stuff to DVD and CD after downloading.
Now, I'm going nuts trying to find one particular thing, and having to hunt
through a bunch of discs. Worse yet, is in a week or so from now, doing
the same thing all over again. (can you say glutton for punishment?)
Anyway, I'm trying to find a good program that can archive what's on a
particular cd or dvd, so that I can label it and search a database, and then
pull the disc in question. I've seen software like this that comes with the
fancy usb connected disc storage devices like the one from KDS. but I'd
like to just find a good piece of software. That way I can use my own storage
boxes for the discs.
Thanks
-Jeff
Excel or Access would both let you do this, or try
edit: yeah, I meant dvdprofiler :rolleyes:
http://rvas.webzdarma.cz/
Cathy (freeware)
"An extremly small, very fast and easy to use media cataloging tool. You can use it to index files stored on removable media (CD-ROMs, LS120, Iomega Zip and Jaz disks, or even diskettes), hard disks or net drives, and create searchable catalogs that can be used without having access to original media. Searching capabilities are based on file name, date and size. Additional features include filtering options, search duplicates or singles, customizable date format, etc. Found files can be opened (executed) or deleted directly, if they are present. Drag&drop support. Directory trees, MP3 album/song lists can be printed, disk space usage can be investigated. Single file executable, no install needed."
dvdprofiler.com
I use it to archieve my 200 some odd dvds and works fine for me
