CD Driver troubleshoot help me plox!
deLuxe.EPiDEMiC
My CD driver opens. And when I put in the CD and close it. But in my My Computer it is no where in sight in the Devices with Removable Storage. I only see my floppy drive. I did disconnect and plug in the wires a lot when I was taking my computer a part to see how I would make my new computer when I get it. Now I don't see it in the place where it should be >=(.
Since you say you disconnect and plug the wires alot, what happens is if it's a IDE cable, the ribbon cable on the IDE connector will get loose and not make good contact. Try using another ribbon cable or, press firmly on the ribbon cable connector to ensure it makes good contact with the ribbon cable.
