CCNP Lab Help
soni
I need help with the modules needed for my routers to complete the CCNP.
My lab is as follows: Currently my routers just have a NM-1FE-TX module in each. Memory is maxed out in all, and they are all running the latest IOS images.
3x 3620
3x 3640
3x Catalyst 2950's
2x Catalyst 3550-SMI running EMI
For those of you that passed your CCNP can you tell me what modules I should have for each router?
Thanks in advance.
3x 3620
3x 3640
3x Catalyst 2950's
Thanks in advance.
WIC-1T + NM's with WIC slots+ Ethernet to connection up to switch's. That's all.
I've got a couple NM-4T1-IMA that i could throw in, could those take the place of WIC-T1?
No, what you want is the WIC-1T, not WIC-T1... they're are different WIC's. What you want to be able to do is setup back to back serial connections, connections to a frame-switch so you can get frame-relay experience(though its not needed for the CCNP). For the frame switch, look into the NM-8A/S. This is why I always recommend.... wait for it..... here it comes... my "autogenerated" post... Dynamips.:p Equipment is such a burden at times.
Not trying to be a dick, but search!
This and every other lab question has been asked hundreds of times at the [H].
You should also have a look at the very first sticky in this forum.
On Topic, 1 NM-8AS and 5 NM-2FE-2W should be sufficient.
