http://www.cisco.com/web/learning/le3/le2/le0/le1/learning_certification_type_home.html
or
http://www.eccouncil.org/certification/ec-council_network_security_administrator.aspx
Which of the two would you suggest picking in conjunction with Systems administration? I know the two professions are on entirely opposite spectrum's of the field, but I'm also interesting in the security aspect of networking (Like securing vulnerabilities in networking infrastructures, routing & switching), and I thought knowing a few things would make be a more valuable sysadmin. Not only that, I just want learn, learn, and... learn some more, and ultimately, have fun!! Now with that said, I don't plan on perusing a career in security, Systems administration will always be my primary interest, I will also head up for this first, or do both because I'm up for the challenge. Initially I was going to drop one based on whether which one doesn't require re-certification because it's expensive as hell, but from what I've gathered, they both require doing so. I think the NSA one is vendor neutral, but i'm not so sure on that. So that notion is out of the window. So what would you recommend? Comments, thoughts?
Thanks
or
Thanks
