Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
im trying to get a stupid potentiometer set up to turn down the voltage to me dual ccfls, can anybody help me find something or suggest what i can use?
im not sure it im able touse just a regular fanbus for it or not.
A simple fanbus will do, i tried it and it works great.
Another benefit is you get a cool pattern with just the ends litten up if you use a low voltage (I got it around 7V)
