D
Deleted member 23757
Guest
I've found an odd problem with the recent 12.4, 12.6 (BETA), 12.6, and 12.7 BETA drivers. There are certain games where the custom created 3D Application Profile will not apply, unless you set "Use As Current Settings" in the CCC "Application Profiles" tab. For most modern games I leave everything default and let he games manage 3D settings. However, there are some older games that a saved profile (using the proper .exe file) will not apply the setting saved in the CCC.
Here are the games I've tested specifically where saved profiles will not apply.
Jedi Knight II: Jedi Outcast (both SP and MP exes)
Jedi Academy (both SP and MP exes)
Knights of the Old Republic (swkotor.exe)
The above games will only work if I set "Use As Current Settings". The below games WILL work properly. By "properly", I mean upon setting up the profile and saving, I return the CCC global settings to default (application manged) so as not to mess up modern games.
Interestingly, UT2004 and Mass Effect 1 WILL work in the intended way. So it seems that the CCC for some reason cannot apply saved 3D setting with certain games with a saved custom profile, only via forcing the current settings (global). This then forces me to access the CCC both before and after playing the game to enable and disable the current 3D settings, defeating the purpose of a saved profile in the first place.
Anyone else seen this? I hope this way clear.
Thanks!
