CCC Presets - are they supposed to do something?
svideo
I've tried to use presets in the past, and have now been attempting to work with them again, but I'll be damned if I can get them to do anything at all.
Example: If I go into extended display mode, select Presets > Add Preset, give it a shortcut, icon, etc, then go into eyefinity and do the same, selecting the preset and clicking apply, launching the icon on the start menu, or use the hotkey - nothing at all happens. Same is true if I try to make presets that have Crossfire disabled/enabled 2 GPUs/enabled 3 GPUs. No matter what I select or how I select it (hotkey, selecting in CCC, shortcut, etc) the screen never even so much as blinks.
No settings have ever been changed or applied with this function across I don't know how many driver versions and 4 reloads of the OS.
I'd love it if this functionality would work. Is this something that people actually use?
I use the CCC profiles/presets for changing fan speeds. I had to reset mine after installing a 7950 yesterday.
I'm not sure about the settings that you want changed in your profiles, but I just deleted my old profiles first.
Then I went to the OverDrive section and set the manual fan speed to 35% and apply. Then "Add Preset" and name it and set a shortcut.
Then I changed the manual fan speed to 50% then repeated the above steps (adding preset,naming it, and setting shortcut).
So what I ended up with is Alt+F8 brings fan speed to 35% and Alt+F10 gives me 50% for gaming.
Not sure if you could apply this method, but for the settings you want to change? Though it sounds like you did the same as me from your description.
Also, I have Catalyst 12.4 I think.
