CCC is jacked up
McClintoc
Every time I try to run my Catalyst Control Center Windows says the "host program has stopped running" and that's all I get. I deleted all my ATI files and did the Remove Program and the reinstalled all my ATI stuff but CCC still doesn't work. Any ideas on what is wrong? I am using Vista Ultimate x64 and my specs are in my sig.
i get the same problem. i would suggest downloading the drivers from the manufacturer of your card. admittedly, the helpfulness of this solution depends on your manufacturer.
Hmm, DL'd and installed the latest drivers. Still not working. Think I'm just gonna do a fresh install of Vista and start all over. CCC isn't the only problem I'm having with my new build.
