CCC Display Profiles
Just a quick question. I got my third monitor and I am fooling around with Eyefinity.
I normally run Extended desktops
Right (Extended), Middle (Primary), Left (Extended)
This is what I use for my "everyday" use.
When I am gaming I change it to an EyeFinity group that spans all three and puts the start menu on the left monitor.
As far as all that is concerned it's working fine.
Now what I want to be able to do is easily (via hotkey) change between my Extended Desktop Everyday Profile and my EyeFinity Profile.
I tried setting up Profiles via CCC but it doesn't seem to be working, When I switch back to the normal profile by selecting it my center monitor is the primary, the left is where it should be but the right monitor (in terms of the desktop) is to the left of my left monitor.
Am I doing it wrong or is this another CCC is broken thing.
I have the same type of problem with CCC. I usually go from my 42" TV to my 22" monitor and have a spare 19", I've set up 3 different profiles and they never seem to work, they will show up as presets but when I switch to them it doesnt do anything
