Cause of Screen Flicker??
Bad Goat
I have a 15" Systemax LCD monitor...up until recently it has been working fine....until one day my computer wouldn't turn on...thought it was the PSU.
So I went through the trouble of grounding the outlet that my computer plugs into thinking that the outlet wasn't pushing the right amount of power to the PSU causing it to not start up, or having some kind of interference(static electricity)...
Now I am wondering if my PSU isn't screwed up in some shape,way or form....I am thinking that my PSU isn't pushing the right power to my mobo, vid card, HD's etc....which would cause interference with any other peripheral connected to it... i.e Monitor to VidCard? Funny thing is though...is my friend and I used a Volt Meter and tested the ATX plug from the PSU and it seemed ok...but my gut just still tells me it is the PSU.
Am I correct in this thinking? Would a dying PSU cause problems like this? or is it the monitor? or is there something else I am overlooking or haven't troubleshooted yet?
Please take a moment to offer up some suggestions.
Thank you.
wow, no replies....
C'mon...some help would sure be nice here before I go out and blow money on a new monitor....:rolleyes:
Yeah, I think I figured out my problem....replaced the Power Cable that plugs into my monitor with another Power Cable I was using on another computer....kinda seems odd to me...but no more flickers....WOOT!
I'm glad you figured out the problem, and had a conversation with yourself all at the same time :).
Anyways, cords go out all the time. It is mostly because you move your monitor and the cable is a little tight and it starts to messup the connector. Also if the cable was pinched or stuck on something on you were moving it it could damage the internal wiring causing tears/breaks in the copper. Also the shielding could be crappy and picking up interference from other power cords. The shielding can be damage even easier then the copper wire inside since it is usually just a jacket over the wire.
