piratepress
- Feb 15, 2002
I want some of what the developers are on.
so the betas of the bench are out, anyone run it? I cant get it to work on my system
still cant get mine to work at all just says allbenchmark has stopped working. I have tried setting everything back to stock, tried running as admin, tried compatibility mode, tried disabling the GTX 650 Ti in my rig, nvidia drivers 310.70, windows up to date, nothing running in the background (teamviewer, fraps etc)... just cant get the damned thing to run. it all points to a ntdll.dll error in the event log.
Same. Very rare that stuff doesn't work for me...this is one of the few. Let me know if you find a fix!
Edit: Doesn't appear to be a driver version issue...plenty of people running 310.70. Running in OpenGL at least shows me a loading screen (DirectX is just a black screen) but it doesn't change my resolution and still freezes/crashes.
just curious when you installed did you install the directx and the other virtual C+ thing i think it was that was part of the install or did you skip those?
Yeah I installed all the optional things. Worked on it a little bit last night...just cant seem to get it running which is a shame because I've been looking forward to it for months now.
I'd be curious to know what kind of system you need to achieve 26k+.
