Catlyst A.I Setting understanding?
newls1
Have 1 question fellas, For the setting "Catlyst A.I" there are 2 options "Standard" and "Advanced" When enabling crossife it says to keep this setting set to "Standard", but what does advanced do? Which setting "MIGHT" improve performance?
apparently the "advanced" side is a newer and more optimized version. Which is said to improve performance very slightly or perhaps even give less performance on older cards.
Advanced AI is a more aggressive mode, which can offer more performance, but there can be some wierd behaviour and performance loss in some games if you use it. Trial and error, but generally it's faster than Standard on a single card.
In Crossfire, it also forces AFR, so it's the way to get games that don't have direct Crossfire support to use both cards, and it can over-ride the driver's method of Crossfire for games that the driver knows about. Sometimes AFR isn't the best method of Crossfire on a particular game.
thanks
