I have 2 Maxline III model 7L250S0 (250 gig 16 meg cache, SATA) drives.
One was in the closet, safe.
The other drive was in my system as a backup. It took a serious dump. The logic board (if that is the correct term) fried somehow. One of the chips on the board is blackened to look at it and it certainly smells like burnt plastic.
The drive does not start up at all.
This fried drive was my back up. I have two drives as backups and I rotate them. This maxtor was the last one to get updated. So I am loosing about 1.5 to 2 months of data.
What I have done.
I tested the other drive and it is perfectly fine.
I took the logic board off the undamaged drive and attached it to the damaged one. It spins up and makes some awful sounds. Bios recognizes that a maxtor drive is attached, but no other information is relayed. No information in Windows XP Pro is available. However, once it spins up the sound goes away.
I have no expectations, but before I call it a total loss, any suggestions on anything I should try?
I have already tried hitting it.
What I have done.
