In the past ATI's driver uninstall was a mess but then last year, part of the CATALYST program, they introduced a proper uninstall utility that was separate from the driver. I had been using this utility for many CAT releases since.
What I wanted to know is, is this tool still necessary or have they integrated its functionality into the actual CAT driver package? By this I mean, when you go to uninstall a CAT driver from Add/Remove Programs will it fully clean itself out of your system or do you need to run that separate utililty I have linked to above?
Look forward to hearing some informed responses, not idle speculation/guessing or straying off topic.
Thanks much!
