MrDowntempo
- Jul 8, 2008
I like how Catalyst lets you set up multiple profiles. They even have an option to let you automatically launch a program when you activate a profile. I could for instance tweak my settings ideally for Crysis and save it as a profile. Then when I choose my Crysis profile, catalyst will automatically launch Crysis. What I need though is a way for a profile to be automatically loaded when I run a specefic program. For ex if I ran crysis, it would automatically start my Crysis profile. I need to do this for PowerDVD. That way whenever I launch PowerDVD, my refresh rate will change to 24hz. Now I know I could set up a PowerDVD profile at 24hz and then save it as a shortcut and launch that whenever I want to play movies, but for my current setup this isn't plausible. I'm using mediaportal as a frontend and that limits the way I can configure this.
Is it possible for me to assign Catalyst profiles to certain apps, and have the profiles loaded automatically when the program runs?
Thanks,
MrDowntempo
Thanks,
MrDowntempo
