Catalyst Etherchannels help
TheDude05
I'm trying to set up Etherchannels for our Proliant DL380s with LACP. Using HP's networking configurator I set the two interfaces to a team with the type as "Automatic (Recommended)". Here are my options
Code:
802.3ad Dynamic with Fault Tolerance
Switch-assisted Load balancing with Fault Tolerance (SLB)
Transmit Load Balancing with Fault Tolerance (TLB)
Transmit Load Balancing with Fault Tolerance and Preference Order
Network Fault Tolerance Only (NFT)
Network Fault Tolerance Only with Preference Order
Then I go onto our switch and set up the port like so..
Code:
interface FastEthernet0/47
 switchport mode access
 channel-group 1 mode passive
 spanning-tree portfast
interface FastEthernet0/48
 channel-group 1 mode active
So did I do this right? Just wanting to make sure before I turn the team on and break stuff :p
