Catalyst Control Center no workie
oldpablo
I have a HTPC I frankensteined together to run Windows Media Center 2005, and it's been great for a couple years now. However the other night for some odd reason the desktop started flipping over and over like an old TV who's channel isn't quite tuned in right. Not knowing if its a bad cable or our crappy projection TV my parents gave us I unplugged it and plugged in flat panel. It seemed to work all of a sudden, but it wouldn't output to the TV anymore (via s-video). So I figured now's a good time to uninstall all the video drivers and reinstall them since there are much newer versions. So I pulled down the latest CCC and tv tuner drivers and installed them, however for some odd reason when I try to launch CCC it just does nothing. So I uninstalled a few times again in various order and I get the same thing, except once it would show the first screen where you choose between beginner or advanced for a split second, and then disappear. Then it would just keep doing that. So I think maybe somethings borked about the .net stuff, so I reinstall all that and I still get the same thing. Any ideas?
x700 video card
550 pro tv tuner
