WhiteFireDragon
- Jul 16, 2009
i just installed the drivers for a HD4890 from the ATI website, and now i'm deciding if i should also use the Catalyst Control Center (CCC) or not. does the CCC come equipped with the tools for huge performance gains or will it just be more bloatware? to my understanding, i'll also need to install the .NET to even run CCC, which will even add on more to the bloatware and resource usage. is it worth it or are the "driver only" package enough?
