Catalyst 8.9 debacle
Modred189
Can't Read the OP
When I saw that the 8.9 drivers came out, I figured they would fix my Crysis:Warhead issues. Well they screwed everything.
First, over the course of the install I get these two messages:
Second, I cannot boot into safe mode, and catalyst control center is not installed, so crossfire is not working. I am going to try and go get the 8.8 package...
Any ideas, [H] readers?
Run windows update or simply download the .NET version you want from microsoft.com
Then try installing again and choose custom, untick NET2.0.
If you have been using ATI cards for at least one driver set, you HAVE .Net 2.0 already.
I think that your driver download was corrupt or didn't download correctly.
If you can...........download the driver set again.
Uninstall the package.
Reboot into safe mode and use drivercleaner.net.
Reload your package.
