[B]GPU BENCHMARK 7.11 Hotfix[/B]
TimeDemo Play Started , (Total Frames: 2000, Recorded Time: 111.86s)
!TimeDemo Run 0 Finished.
Play Time: 34.04s, Average FPS: 58.76
Min FPS: 40.90 at frame 1943, Max FPS: 82.16 at frame 873
Average Tri/Sec: 42842384, Tri/Frame: 729164
Recorded/Played Tris ratio: 1.26
!TimeDemo Run 1 Finished.
Play Time: 31.34s, Average FPS: 63.81
Min FPS: 40.66 at frame 1973, Max FPS: 82.31 at frame 71
Average Tri/Sec: 46973900, Tri/Frame: 736123
Recorded/Played Tris ratio: 1.25
!TimeDemo Run 2 Finished.
Play Time: 31.25s, Average FPS: 63.99
Min FPS: 38.88 at frame 1963, Max FPS: 86.76 at frame 129
Average Tri/Sec: 47100672, Tri/Frame: 736011
!TimeDemo Run 3 Finished.
Play Time: 31.46s, Average FPS: 63.56
Min FPS: 38.88 at frame 1963, Max FPS: 91.60 at frame 113
Average Tri/Sec: 46791148, Tri/Frame: 736116
TimeDemo Play Ended, (4 Runs Performed)
[B]GPU BENCHMARK 7.12[/B]
Play Time: 35.44s, Average FPS: 56.44
Min FPS: 38.88 at frame 1953, Max FPS: 80.35 at frame 1007
Average Tri/Sec: 41127776, Tri/Frame: 728686
Play Time: 31.65s, Average FPS: 63.20
Min FPS: 38.88 at frame 1953, Max FPS: 94.23 at frame 95
Average Tri/Sec: 46500592, Tri/Frame: 735797
Play Time: 31.68s, Average FPS: 63.13
Min FPS: 36.85 at frame 1941, Max FPS: 94.23 at frame 95
Average Tri/Sec: 46470396, Tri/Frame: 736150
Play Time: 31.61s, Average FPS: 63.28
Average Tri/Sec: 46603012, Tri/Frame: 736469
Recorded/Played Tris ratio: 1.24
[B]CPU BENCHMARK 7.11 Hotfix[/B]
TimeDemo Play Started , (Total Frames: 1500, Recorded Time: 44.62s)
Play Time: 29.29s, Average FPS: 51.22
Min FPS: 32.50 at frame 196, Max FPS: 80.32 at frame 344
Average Tri/Sec: 43108952, Tri/Frame: 841668
Recorded/Played Tris ratio: 0.85
Play Time: 24.95s, Average FPS: 60.11
Min FPS: 32.50 at frame 196, Max FPS: 80.54 at frame 368
Average Tri/Sec: 50618208, Tri/Frame: 842103
Play Time: 25.12s, Average FPS: 59.72
Average Tri/Sec: 50601836, Tri/Frame: 847259
Play Time: 24.91s, Average FPS: 60.21
Average Tri/Sec: 50783668, Tri/Frame: 843398
[B]
CPU BENCHMARK 7.12[/B]
Play Time: 26.24s, Average FPS: 57.16
Min FPS: 40.31 at frame 831, Max FPS: 83.45 at frame 351
Average Tri/Sec: 41248536, Tri/Frame: 721656
Recorded/Played Tris ratio: 1.00
Play Time: 23.57s, Average FPS: 63.64
Average Tri/Sec: 45854524, Tri/Frame: 720526
Play Time: 23.66s, Average FPS: 63.39
Average Tri/Sec: 46277360, Tri/Frame: 730046
Recorded/Played Tris ratio: 0.99
Play Time: 23.12s, Average FPS: 64.87
Average Tri/Sec: 46674764, Tri/Frame: 719542
Why doesnt it sound like people are so happy with these drivers? I dont have the time right now to install them (im at work) but what is the bottom line with these and Crossfire 3870's??? Anyone know? I did multiple searches and didnt really find anything about my question.... Thank you
Is anybody noticing weird colors in firefox with these drivers? Like some of the links here on the [H] are blue?
Everything was fine with 7.11
If no one else has any problems I guess I'll go back to those.
This release of Catalyst introduces an enhanced version of ATI OverDrive for the ATI Radeon HD 2900 Series. Users can now Overclock both GPU engine and graphics memory clock speeds in CrossFire mode (and over-clock single ATI Radeon graphics accelerators as well). This version of ATI Overdrive also
Performance Improvements
The following performance improvements are noticed with Catalyst 7.12:
* 3DMark2005 performance improves 5% or more with largest gains noticed when Anti-aliasing and Anisotropic Filtering are disabled on systems containing either an ATI Radeon HD 2400 or ATI Radeon HD 2600 series of product* Company of Heroes DX10 performance improves up to 5% on systems containing an ATI Radeon HD38x0 series of product
"Since the OP is either too lazy, or too incompetent to leave a link, here it is. Nevermind
the fact that no other information was listed. If you're going to make a thread.. make it right."
I'm sorry to you and everyone else that doesn't know exactly where to get these. I apologize to the people whose intelligence (commonsense) I DIDN'T insult.
I would post a link that explains how to wipe your ass or for that matter, does it for you, but I guess I'm too lazy.
We're done here.
We're done here.
Dont be upset that I called you out on your laziness. The fact is, its common forum procedure to drop at least a link, when announcing new software updates or drivers. Sure everyone can get it themselves. Its much easier for the person who makes the thread, to drop a link, and to even paste what the improvements are. Which helps people who ask questions like, "Does this include the Crysis fix that was in 7.10 (Hotfix) but not in 7.11?" such as was posted in this thread.
Now we're "done".![]()
I'm getting the funny colors but no crashes. I've decided to ignore the colors and stay with 7.12 because it seems to run COD4 much smoother than 7.11.I'm getting the funny colors and occasional crashes while just surfing.
Memtest and small fft orthos showing no issues, nor when playing stalker.
