Catalyst 7.10 drivers won't install...
Lyquist
I am getting an error under Windows XP when I try and load the drivers. Something about having to run in administrator mode, and I am the administrator. I tried doing "run as" and then choosing administrator with the correct password, but that didn't work either. Thanks in advance for your help.
Noticed the same error as well. I follow this procedure:
1) Unistall via/add remove software.
2) Restart.
3) Cancel plug n play wizard.
4) Run the .exe
Here is where I received the "Must run as an administrator" message from hotfix 7.9, and 7.10. To resolve it I needed a second reboot, cancel the plug n play again, and run setup from the extracted directory under C:\Ati\Version number.
5) Restart when installation is finished.
