Catalyst 6.2 DOWNLOAD
For myself (X1800XT and X1900 Crossfire), these performed MUCH better than the 6.1s.
X1800XT 512 with: 6.1 3DMark06 - 4117
X1800XT 512 with: 6.2 3DMark06 - 4432
X1900 Crossfire with 6.2 - 47**
Are those low?
Those scores are right on.
I've got an X1800 XT from ASUS and I get 4040 or so on 3Dmark06. With Cat 6.1
Are those low?
Offtopic:
You actually have a rig with x1800xt and a rig with 2 x1900xt ???
Russian said:
Offtopic:
Oh god no. If I had that kind of Money I'd buy Monica Belluci for one night and suffer the wrath of the Wife in the Morning.
I had the X1800 in my system, ran the benchmark, then did the driver upgrade, then ran the benchmark.
Then I took out the x1800 and put in a single X1900 Crossfire (It's an XT but is the mastercard.) I may upgrade with another X1900, but I have books to buy for class next semester.
lol, So you have a x1800xt and one x1900 xfire mastercard?
And i would take jennifer aniston over monica belluchi (whoever she is)
Are those low?
I got 4576 with Catalyst 6.1. Hopefully these new drivers would put me closer to 5000 :p
I wouldn't count on it...but does it matter?
No it doesnt matter but a 300 point increase has to mean something as far as performance wise and hopefully my games run faster. 300 points for me would be mean.....4876. Isn't that close enough to 5000?
Also, if you didn't notice, i said the word "Closer." I never said would get 5000
l337x3r1cx said:
the 6.2's got me from 4949 in 06 to 5227 and in 05 from 106XX to 111XX
Are you using .net 1.1 and the CCC or another control app for the 6.2 drivers?
Thanks!
A quick comparo....
They are a keeper for me. Fianlly broke 6K in 3dmark06 :)
HL2, FEAR, WoW & SWG seem to all play fine.
2-3-06
ATI1900XTX 698 core, 797 mem (CPU@14*210=2940) Drivers From ATI 1900XTX CD
Aquamark 107,049
3dMark06 5906
3dMark05 12115
3dMark03 19810
3dMark01 35334
2-7-06
ATI1900XTX 698 core, 797 mem (CPU@14*210=2940) Catalyst 6.2 Beta
Aquamark 106,845
3dMark06 6261
3dMark05 12448
3dMark03 19971
3dMark01 35470
6.2betas made reaching 12k soooo easy and with room to spare on mem side of my HIS X1800XT and only using a single core Opteron 148! :eek:
Opteron 148 @3102mhz
512MB HIS X1800XT
@621/747 = 9,543
http://service.futuremark.com/compare?3dm05=1783870
@756/900 = 11,335
http://service.futuremark.com/compare?3dm05=1783893
@816/963 = 12,040
http://service.futuremark.com/compare?3dm05=1783908
Opteron 148@3102mhz
X1800XT @816/963 CAT 6.2Betas
vs
Opteron 170@2950mhz
X1800XT @816/981 CAT 5.13
And 3dmark06 looks okay even with single core
@756/900
cat 5.13 = 4,621
http://service.futuremark.com/compare?3dm06=111233
cat 6.2 beta = 4,994
http://service.futuremark.com/compare?3dm06=111286
@816/945
cat 6.2 beta = 5,260
http://service.futuremark.com/compare?3dm06=111573
my 6.12 beta results with x1800xt flashed to 700/800
6.1
3dmark05 - 10013
3dmark06 - 4576
6.2
3dmark05 - 10236 +2%
3dmark06 - 5083 +11%
Im very happy with results
Floppor said:
is there a list about the patch with changes?
yeh it would help....
and does it seriously not recognize the x8xx and x85x series? thats annoying :(
Hey guys. I'm stuck in newly back to ATi hell. I just got my x1900xt last night. I tried these drivers and the 6.1's but I still had problems with proper resolutions for my FW900. There was nothing in the 1600*1024 or 1680*1050 range and the resolution choices were extremely limited. I took it off BNC, went back to VGA and same problem. I tried 6.1 and then installed the Omegas on top and at least I have proper resolutions. (Ati Tray tools crashes my system hard tho).
It was all rather annoying. I tried powerstrip and looking through the ATi driver but I didn't find the proper settings or override. I saw where i could force some refresh rates and so on but they weren't custom, and the thiing was still had 1600*1200 and a bunch of other 4:3 stuff but not what i was looking for. Overclocking with the Omega's, powerstrip, or ATiTool I ended up staying away from because it just had one set of clocks and seems to be just my 2d clocks.
So I can wait for 6.2 Omegas but I'd still be up for finicky overclocking. :( I just wasted too much time fiddling with this thing. What are guys doing for custome res'es and also properly overclocking the card in 3d mode?
l337x3r1cx said:
.net 1.1 and ccc
Thank you! Will check it out later tonight and see how the games are performing. I'm still a little leary about installing all this .net jazz, though...
The 6.1's will NOT work with the X1900XT(X) cards.
Well aren't the ones on the cd slightly modded 6.1's? Anyways, I used those. I'd hope the driver cd had something usable. WIth Omega 6.1's on top. Might seem wonky, but hey, that's my best option right now.
Good question. If thats the case, than I stand corrected. You have tried the beta Catalyst 6.2 as well, to no avail?? Might be best to just wait for the final Catalyst release 6.2 if thats the case...
B33
Yep, tried 'em. Problem is I can't get pure ATi drivers to give me proper widescreen resolutions. Only thing proper is 1920*1200. So.... maybe because I'm an ATi noob, but for NV not only did they pick up most of my settings, I could add them like nothing. Click add custom resolution, pick refresh, apply, then ok. Then all set. I see something that looks similar but it's all run by drop downs with the same crappy ass, mostly 4:3, options.
Reading the boards seems people use hosts of apps to OC etc. There is no doubt I'll get used to it and find my proper OC apps plus driver options. But it's simply impossible to argue this as well put together as Nv options. Impossible. Nv + CoolBits is miles more intuitive. Hope no ones offended but if they could give me some advice to get on the fast track of muddling through this junk I'd appreciate it.
have you tried the 'displays manager' tab in the Cat Control Center?
Does CCC properly identify your monitor?
Does the regular display properties window?
Have you tried updating the monitor driver?
If yes to all them then i'm stumped.
Just tried the 6.2 betas myself and rather impressed.
in 3d mark 2006 i have gone from 5487 to 5934. SOOOOO close to the 6k mark. Maybe when the proper 6.2's come.
And in the X3:Reunion Benchmark i get an extra 2fps average.
X3 - Reunion
Game version: 1.3.0.US
Graphic card name and driver used: Radeon X1900 XTX Version [6.14.10.6587]
CPU name: AMD Athlon(tm) 64 X2 Dual Core Processor 4800+ Family 7 Model 3
Video settings during benchmark:
Screen resolution: 1920 x 1200 * [32]
using shader profile: 3.0
Antialias Mode: 4x
Anisotropic Mode: 8x
Graphic & Shader settings
Texture quality: high
Shader quality: high
High quality bumpmaps: enabled
Environment map: enabled
Postprocessing: enabled
using 16bit vertex format: yes
Framerates
Scene 00 46.2 average fps 38.0 minimum fps 69.0 maximum fps
Scene 01 39.4 average fps 21.0 minimum fps 73.0 maximum fps
Scene 02 50.8 average fps 42.0 minimum fps 73.0 maximum fps
Scene 03 57.6 average fps 31.0 minimum fps 117.0 maximum fps
Overall average framerate: 48.5 fps
(c)2005 EGOSOFT
For more information http://www.egosoft.com
Nirad9er said:
I just wanted to let you know I got above 5000. ~500 point increase. :D
Huh. Wasn't expecting that at all.
The set on the CD are 5.13 package 8.203 with entries for X1900 cards.
Changes? Wonder if ATI will ever implement dual-core optimizations for OpenGL, or if they will improve the current ones for D3D.
I gained apx 200 pts from cd driver to 6.2 beta.. I have no OC on proc or mem / timings.. I have only clocked the card through the cat control center..
core / 665
mem / 797
3d05 : 9740
3d06 : 5526
with more oc'ing I hope to jump a little :)
Running my X2 4400 at 2.4ghz and my 3DMark06 score went up to 5550. I'll OC the card later tonite. Ran the overclock last night on it, using CCC, and it would just keep crashing.
Any bug fixes?
Does it fix Quake 4 Ultra quality? Anything else?
Apallohadas said:
That is correct Sir!
And Monica was in the Matrix. Remember the Frenchman (Merovingian) from the Matrix: Revolutions? Well she was his hot hot wife with the beautiful .... eyes.
http://www.bellezzevip.com/attrici_italiane/monica_bellucci/monica6grande.jpg The pic is safe for work.
She also played the with in the Brothers Grimm.
Completely Off Topic, yet VERY important. I used to have some wallpapers of Monica Bellucci that were large and hi res. One in particular of here in a waterfall in her burt-day suit. :eek: Someone find? Mine! Mine!
Whack. XTX on 6.2 WHQL scored 5300 3D06 points.
Reinstalled the 6.2 beta's and I'm back at 6001 3D06 points :confused:
