Catalyst 5.9 released
Heres the important parts:
Issues Resolved in Catalyst™ Software Suite 5.9
The following section provides a summary of the issues that have been resolved in the latest version of Catalyst™. These include:
Battlefield 2: The game no longer exits to the Windows desktop after the game logo is displayed
Endorphin: Running the application under Windows XP no longer results in hesitation being noticed during simulation or playback
Max Payne 2: Erratic mouse pointer behavior is no longer noticed within the game's menu after a short time period of game play
MU: Opening a chat window and playing the on-line game no longer results in Hesitation being noticed when pressing the Enter key
Silent Hunter 3: Enabling all video options within the game and setting the particle density to 100, along with setting Anti-Aliasing to 6X and Anisotropic Filtering to 16x, no longer results in display corruption on the left portion of the display
Star Wars Knights of the Old Republic 2: Running the Dantoonie level of the game no longer results in hesitation being noticed
Terminator 3: The game no longer fails to respond and a VPU Recover message no longer occur after loading the game character
The Catalyst Control Center no longer displays blank pages when quickly exiting and re-launching the Catalyst Control Center while hot-plugging or hot-unplugging a CRT display device
Installing an All-in-Wonder into a system containing an ATI Radeon Xpress 200 series and an ATI Theater 550 Pro no longer results in loss of signal error message when setting the country region to Sweden
HDTV support may still be displayed within the control panel with ATI products that do not support HDTV
Connecting two display devices using the DVI and CRT connectors on a system containing an ATI Xpress 200 results in the system failing to resume when entering standby state
Catalyst Control Center: The Overdrive Automated Clock Configuration Utility may continue running even after the user selects apply or cancel in the utility's confirmation window
Connecting two display devices using the DVI and CRT connectors on a system containing an ATI Xpress 200 no longer results in the system failing to resume when entering standby state. Further details can be found in topic number 737-19538
Catalyst Control Center: Connecting a TV as the only display device to an ATI Radeon X300/X600 series no longer results in the Signal Format found in the Adjustment page of the TV Properties being labeled as Unknown
Three of the four ATI entries found in the Add or Remove Programs for Windows XP Japanese version, are no longer displayed in English
The Catalyst Control Center shortcut is now removed when selecting to uninstall the ATI software driver
Catalyst Control Center: The Overscan slider bar now displays a Minimum, Medium and Maximum setting for All-in-Wonder SCART boards
WDM version numbers are no longer documented in the Information Center of the Catalyst Control Center for ATI products that do not support WDM drivers
An intermittent error message is no longer experienced when selecting all of the aspects within the Catalyst Control Center quickly
The limited account user no longer has the ability to add a short cut for the profile manager in the system tray
Overdrive settings no longer revert back to the default setting when connecting a secondary display device and enabling extended desktop mode
Moving the slide bar found in the Adjustments aspect of the Catalyst Control Center are now restored to their pervious levels when clicking the discard button
A horizontal shifting issue when using the capture application is now resolved
Changes to the audio settings are now retained after a system reboot when using the ATI Theater 550 Pro
Resuming from suspend mode no longer results in the audio level returning to its default value
Poor quality of static texture and scrolling text when watching live TV on system containing an ATI All-in-Wonder X800 series product is no longer noticeable
Catalyst Control Center: The hot-key list is now dynamically populated to reflect the enable/disable status
The Use Manual Detection Only translation for traditional Chinese is now correct
The Overscan/Underscan option found in the Catalyst Control Center has now been translated properly for the Russian language
The ability to navigate within the Catalyst Control Center while a confirmation dialog box for the Catalyst Control Center is displayed is no longer possible
The Apply button is now available when making a change to 3D aspect page in the Catalyst Control Center
Intermittent launch failures of the Catalyst Control Center is now resolved
Connecting two display devices to the Radeon X700 using the DVI and CRT connectors no longer results in display corruption being noticed when booting Windows XP
Connecting an HDTV and a CRT display device followed by disabling the CRT and rebooting the system no longer results in the HDTV failing to display an image and the CRT becoming active again
HDTV support no longer fails to be detected properly after connecting a CRT and TV to the ATI Radeon Xpress 200 series
Display corruption is no longer noticed on the secondary display device when disabling extended desktop mode
Setting Anti-Aliasing to 4x in the Catalyst Control Center no longer results in a blank window or an error message being displayed when launching Java plug in
Hesitation is no longer noticed during the opening cinematic of Madagascar when rotating the display device by 180 degrees
Display corruption is no longer noticed when running the Codecreatures benchmark when the FrameBuffer is set to 64MB on system containing an ATI Radeon Xpress 200 series
An extraordinarily long delay is no longer noticed when resuming from an S3 state
Overlay corruption is no longer noticed when turning off the primary display device in systems containing an ATI Radeon Xpress 200 series
The display resolution options of 800x600 and 640x480 mode are no longer available within the Display Manager aspect after rotating a desktop that is rotated by 90 or 270 degree
Running 3D billboard under XP and having the application window display on the left side of the primary display, no longer results in the 3D screen image staying on the left side when dragging the application to the right side of the display device
A black screen image is no longer displayed when entering a full screen DOS prompt when using an ATI Radeon 9800 XT under Windows XP
The Windows XP Professional x64 Edition operating system no longer prompts the user for confirmation of the un-install of ATI Parental Control when running the ATI un-attended un-install
Entering standby mode under the Windows XP operating system no longer results in display corruption being noticed or the operating system failing to respond
Display corruption when using the TV-Out composite setting has now been resolved for the ATI Radeon Xpress 200 series
Video corruption is no longer noticed when playing a DVD under Windows XP MCE
Live TV no longer appears choppy when using and ATI Radeon X300 and two ATI Theater 550 Pro tuner cards and outputting to PiP in PowerCinema
Video jitter is no longer noticed when playing back video using overlay with DXVA
The German language control panel text no longer appears truncated when using 96 DPI
Known Issues for Catalyst™ Software Suite 5.9
The following section provides a summary of open issues in the latest version of Catalyst™. These include
City of Heroes: Playing the game under Windows XP Media Center Edition may results in display corruption being notice when attempting to task-switch between the game and the desktop. Further details can be found in topic number 737-19792
Prince of Persia: Sands of Time: Attempting to launch the game under Windows with an ATI Radeon X800 XL installed results in an error message being displayed. Further details can be found in topic number 737-19787
The Apply button in the Custom settings of the Advanced mode found under the Catalyst™ Control Center Video standard settings is grayed out when playing a media file. Further details can be found in topic number 737-497
Connecting an HDTV to an ATI Radeon X700 series may result in the HDTV being detected as a CRT or TV under the Windows XP operating system. Further details can be found in topic number 737-20575
Attempting to install the integrated WDM driver under Windows XP may result in an error message being displayed indicating that the hardware is not installed because the install Wizard cannot find the necessary software. Further details can be found in topic number 737-20576.
Connecting a CRT and a TV may result in the TV not being automatically detected under Windows XP MCE when using an ATI Radeon 9550/9600/9650 series. Further details can be found in topic number 737-20577
Using the Custom option when installing the software driver results in the Theater 550 software driver not being present. Further details can be found in topic number 737-20579
asianguy80 said:
oh I didn't realize that ahahaha silly me :D
The drive name actually indicates the release date. The numbers go like this.
x.y
x= year
y= month
5.9 = 2005.9th month (Sept.)
That's why the 4.x releases stopped at 4.12 and then went to 5.1.
Yeah, they release them each month, but I think I know what you mean. I thought this last month just went by freaking quickly. o_O
W T F
is up with the new download system BS from ATI?!?!
I'm not going to install some crap just to download drivers which have NEVER needed some special download delivery system
(if you hit no enough if will just give you the link)
:D
oldmx
x.y
x= year
y= month
Oh, I never noticed this when I had my ATi 98Pro AIW lol, afterwards I switched to a 66GT now I'm back on the XL. It all makes sense now :D
monster.under.thebed said:
cp or ccc?
and what software do i need to remove my old drivers? i tihnk im using 5.7....
You need Driver Cleaner
x.y
x= year
y= month
i also didnt pay attention to that. thanks for the heads up
Lazy_Moron said:
So how do these perform?
Haven't really run any game benches, but HL2 and the Serious Sam 2/F.E.A.R. Demos all run great, just like they did before. Oddly enough, and this has never happened before when "upgrading" drivers, but I got the exact same 3DMark score as with the 5.8s. So, for me, they perform just fine.
pandora's box said:
apparently theres no more truform option in the drivers. stupid if you ask me.
Anybody besides Pandora here use truform? To be honest, I couldn't tell the difference in terms of appearance or the supposed performance hit that it caused.
well i dont use it but several of the beta testers for ati over at rage3d commented on how it isnt braking anything and since it isnt braking anything why not just leave it in the driver.
Juicy_Red_Apple said:
thank god they've sorted the BF2 fix.
Indeed... That sometimes got on your wick... And really want to hurt someone... or something :p
I think that error is hillarious. I dled the 5.9s, uninstalled my drivers and used Driver Clearner to wipe my system and installed them. I didnt test them too much since I had a pile of HW that day but I did play GW and DOD (I know not good testers) and noticed no image quality diffrence nor speed diffrence. I did notice that Sage TV had much better Image quality than before. So I ask.... Did the 5.9s affect my Theatrix 550 pro?
ok........i got a 180 3Dmark jump from 5.8 to 5.9 thats really good!! stock speeds.....in the 5.8 thread i said maybe the 5.9 will get me to 6000 but yet it brings me to 6150!! very satisfied!
Hmmph, yeah I got about 100 points, and I almost want to say the image quality is a bit better, but unsure....
me=stupid noob again. I grabbed the wrong cat 5.9 file the one needing .net. so instead of getting the right one i went ahead and installed .net. :mad:
I am using 5.7 right now, and I have no problems. bf2 runs great. I'm just worried that the new drivers will stop bf2 from working. Any issues with bf2?
I think im going to stick with my 5.8's and wait for a few more releases before I install a new one. As of now, it runs everything I do (including BF2) really well.
whata re yall using? in 5.8 i used CCC but this time around im using control panel just CCC takes for ever to load up
I use control panel because, even though they have improved CCC, it is still slower and more memory hungry than control panel. The extra features aren't worth it to me. In addition, .net is a resource hog that I can do without.
They gave me 49 more 3dmark2005 points, so i cant complain.
Still not at 7k though :(
ok 5.9 sucks for bf2 for me it keeps crashing to dektop
EDIT nm i was o/c my processor too much drivers work great
EDITagain - it did it again WTF
I still don't see any compelling reasons to update my drivers..there aren't any fixes i care about at all.
