Ultra Wide
- Jul 23, 2000
I recently re-wired my condo for data. There was CAT5e cable already present so I changed it from the voice to data. I am concerned whether my connections are good enough. I read that you should not unstrip more than 1/2", but these cables were stiff and very hard to work with. I did un-bind some pair a little too much maybe? I keep hearing about twisted pairs and cross cancellation and not being able to achieve 350mhz(gigabit) unless the twisting is top notch.
What do u think? Do I need to redo the wires so the pairs are more tighly twisted together?
I did an initial test with 100mbps and it works fine, but not sure at gigabit speeds.
