Have you guys found any reliable CAT5 line testers? I have to test 30+ cables that are not labeled and need to see why I do not have a connection for just a single line.
Not necessarily purchased from there, Google and/or PriceGrabber.com and look for the best price. They might even have it at Home Depot.
I have one and love it. It has ports for RJ-45, RJ-11 and Coax. It has a remote unit that you plug into the other end and works as a tone generator also.
Note: It comes with two patch cables to enable you to plug either cables in or plug into existing jacks (male and/or female). When I tested some data cables the first time I got errors that threw me for a loop. Then I tested the patch cables that came with it and got faiures on both of them. Not sure if they are wired to an old standard or what.
