I have a media server in my house that I want to stream blu-ray movies to 2 different HTPC's in my house. HTPC 1 is on the same level as the media server and about 60 feet away. The HTPC 2 is upstairs directly above the other HTPC 1.
I'm going to run a single Cat 6 cable from the server to the HTPC 1 on the same level and use a switch to hook up HTPC 1 and other peripherals that go with my home theater.
Since HTPC 2 is right above HTPC 1 I was wondering if I could run a cat 6 cable from HTPC 1's switch to HTPC 2 and not have bandwidth issues if both are simultaneously streaming ?
Basically, I want to know if the single cat 6 cable in the initial 60' run from media server to the HTPC 1 will be enough to handle both HTPC 1 and HTPC 2?
