Cat 5.13 Tweaks!
Mikey20
Well I just downloaded the Cat 5.13s with CCC and it runs great so far. I ran Half-life 2, Doom3, Quake4, Farcry, Call of Duty 2 and Battlefield 2 and they all run smoothly with no problems can't really tell that much of a performance increase from the 5.12s though i did run CS benchmark and gained about 15fps...well maybe a little Image quality seems about the same too.
I was wondering im somewhat new with CCC and I would like to know what under 3D then All Settings...
1. What is Catalyst A.I and should I have that Enabled or Disabled?
2. Under 3D then API Specific where you have both Direct 3d, and Open GL settings. Under Direct 3d should I have all checked?
a. enable geometry instancing
b. Support DXT texture formats
c. alternate pixel center
And OpenGL settings
a. tripple buffering
b. force 24bit z-buffer depth
What should be checked (enabled) and what should not? My system specs is in my Sig.
If you have sigs off ....here you go.
Intel Pentium 4 2.8Ghz HT
Biostar P4TSV 800MHz FSB 865G/ICH5 Chipsest
2gigs PC3200 DDR400 4 x 512 Corsair XMS TwinX Dual Channel Memory 2-3-2 (2048mb)
120Gig 7200rpm ATA-133
Sound Blaster Audigy 2 ZS
Ati Radeon X800 XT 256MB (537/1166) Cat 5.13s
Windows XP Home SP2
