I am building a new system.
E6600
Ultra X heatsink http://www.enzotechnology.com/cpu.htm
Gigabyte P965-DQ6 v3.3
Cruicial 2gig Kit Ballistix http://www.crucial.com/store/partspecs.aspx?imodule=BL2KIT12864AA804
X2900XT ( its designed for DX10, so all the reviews which are based on DX9, I believe are not doing it justice, also the drivers need to get optimized properly, Nvidia has had time to do so).
The rest of my components will be reused from my current system such as HDD, DVD, X-fi card.
There are actually 3 areas I need help on...
1. Cases ( I have a original P180 ) which is a sweet case but I am planning actually put add in a 1000w PSU. Will this case be able to house it? Even if I remove the fan at the bottom?
2. If the P180 case will not be good enough, Will the ThermalTake Armor ( not Jr ), or the Antec 900 be good enough?
3.Which 1000w PSU have people used and recommend? Enermax, Thermaltake ToughPower, OCZ, or Silverstone?
HELP!
Thank you
E6600
HELP!
Thank you
