kwest4peace
- Jan 2, 2006
I'm going to be doing my first custom water cooling build with the help of a friend. I was wondering if anyone had any suggestions for a nice roomy case that doesn't look like ass. The stacker seems to be what a lot of people go with but its not the nicest looking case. So far the system I'm going with is a Danger Den Single 5 1/4" Bay Reservoir, Storm cpu block, Swiftech MCP655 pump, Danger Den NV-78 gpu cooler with 1/2" ID clear flex tubing. I'm not sure what radiator to get yet because I don't know how much room I'm going to have in the case since I haven't picked one out yet. The new Lian Li cases that are reverse mount aren't good for the board I have (a8n32) because of the heat pipe on the chipset from reviews I have read. However, I'd be willing to take the heatpipe off and get a block for the chipset also if need be. What I'm looking for is something big enough to fit everything inside thats not completely ugly to look at. I'm going for more performace than looks because I want to try and get my opty 170 to 3.0. If you have a suggestion on rads I'll take those too.
Thanks in advance
Thanks in advance
