Cases with washable dust filters
Shuk
Hey guys, I'm really looking to combat dust in my next build. Ideally, every air intake would have a filter so I would just have to wash the filters every once in a while and not worry about dust at all. Please try to suggest cases under $200 please, but any mention is good. Thanks.
Lots of cases have these now.
The Antec P180 through the P193 have filters on the front intakes, these cases go on sale often and can be found from about $100-$175. They are also good at dampening sound, but are heavy since they are steel.
For a bit over $200 the Silverstone FT-01 has good filters, but the filter on the top fan is hard to remove. I've found this case to be really good at keeping dust out though. Its designed as a positive air pressure case, so air goes out of the cracks instead of coming in with dust.
The FT-02 is coming out soon though and the filters are easier to remove.
While filters help limit the amount of dust that gets in your rig, they don't completely eliminate it. You'll still have to blow it out occasionally.
Have you looked at dust filters like these?
I have an Antec 1200. I pull out my filters and wash them every couple months. They don't stop it all, but while I have the side panel off, use a can of compressed air. Overall the filters help quite a bit, I don't get those large dust bunnies hiding in my case at all.
