Hey everyone,
Please forgive me if this is in the wrong forum I wasn't sure where to put it.
I'm planning on building my next new system from Newegg and I decided I want it to be a based on a P4 3.0Ghz Prescott ... I also decided that I liked the specs on this motherboard..
ASUS P5LD2 Socket T (LGA 775)
http://www.newegg.com/Product/Product.asp?item=N82E16813131538
Under the features section it shows that it has a 24 Pin power connector. I've been out of the loop on this for a while so I was wondering if anyone could recommend a case w/ PSU in the $50-$75 range that would support this motherboard? I tried searching Newegg specifically for cases with 24 Pin power connectors but it was pretty confusing. Also I'm not looking to do any overclocking. I'm hoping you guys can recommend something Newegg carries.
For reference what will be in the system...
P4 3Ghz Prescott (Probably with stock HSF)
Radeon X1300Pro PCI-E Video card
PCI SB Audigy
1GB DDR2 667 (2x512)
30 GB Maxtor HD 7200RPM
Thanks!
Paul
PCI SB Audigy
Thanks!
Paul
