Caselabs HD casters kit?
wasteomind
Probably a long shot but I'm looking for some HD casters for my caselabs th10. Seeing as how caselabs went under, does anyone know where i can find a place that might have stock of this kit, or maybe who caselabs supplier was for casters?
I'm guessing McMaster part # 24215T47 or 24215T52? (Depending on whether a 1.5-inch or 2-inch size mounting plate). Good luck!
Just looked over the set for the SMA8 and I cannot find a part number on the outside/inside.
Okay, just checking, I was going through some stuff and found a set that were never used.
I have actual caselabs casters. I would trade them for the usb 3 caselabs powerbutton panel. As i dont like my case on tge floor on casters anyways.
I'm wondering if the Thermaltake casters that come with the Core P100/P200 cases are compatible given that they are blatant copies of Caselabes cases?
