Topic Title : [Casebuild]=[Project: Lightning Case]
Project : Lightning Case
Goal : Create and build a good looking case that is functional and provides silence!
Pictures : Clickable thumbs!
-==[ About lill me ]==-
Well first of all, welcome @ my BiP (Build In Progress)
oh...and i like casemodding to.
Since i started with casemodding i got a lot of positive comments and now i have this tickeling feeling again.
So i will be building my own case!
Here are 2 pictures of my current (out dated!!) case:
-==[ Specs ]==-
The hardware from my current computer will pe put in this new case.
i don;t need a whole new faster case...and since i can not afford that either i will re-use my current hardware!
ATM this hardware is as followed:
Mobo : Asus P4P800
CPU : Intel P4 2.6Ghz HT @ 3.1Ghz
Memz : 2 x Corsair 256MB PC3200 (dual channel) (timings: 2.5-3-3-7)
GPU : Albatron GeForce 4800 SE
Storage : 2 x 7200rpm IDE Western Digital HDD total @ 320GB
PSU : 450Watts
Cooling : A self modded Koolance External Watercooling
Monitor : A 9 year old 17" IIYAMA visionmaster 400 (my first self-bought computer part)
-==[ The Project ]==-
Well so far the hardware part.
Before i started this project i modded my current case, as i liked the result...i didn't like it for long.
I feld the need of modding again!
So i started to design a case, it had to be a good case,
airflow wasn't needed because i use an external watercooling
which gives gr8 cooling to my cpu (29 degrees celcius in the summer!)
So i wanted my hdd's completely silent.
ATM i have wrapped my hdd's in sound isolation mats (yes i "cool" the hdd's to...with a home made copper tubing frame)
I figured that the best way to sound-isolate something is to let air between the source of the sound and the isolation.
This means that i needed a rather large space for my hdd's.
No problem!
-==[ The Design ]==-
My design is quite simple.
In the bottom of the case there is going to be a second bottom/compartment.
this compartment will be 20cm wide, 20-30cm long and about 15-18cm high, room enough for 2 hdd's + isolation.
i figured that, since i don;t really need the airflow, i could also put my PSU inthere...so i am planning to do that!
The whole case will be about 65cm high, lotsa room in this baby...just the way i like it!
as i told before, i have a koolance watercooler, i want to make it look like it is a part of the case.
I am going to do this by not making a top-plate for the case, the exos will be my case-top.
And the plating will cover about 5mm of the exos.
As any casemodder i do not like to see cables in my case!
So i will be placing cable ducts in this case (for power and ide)
this way we won't see any of those ugly cables...or at least not much.
In the front of the case there will be a Plasma Ball.
Since the theme of the case is Lightning and i really like nice thunderbolts i wanted this very much
So santa gave me a nice plasma ball this christmast:
This plasma ball will be placed in the middle of the front of the case, u guys will see.
Well...enough talking!
let's look @ some pictures!
-==[ Log-Start: 01-01-2005 ]==-
I forgot to make a picture of the loose materials so here's 1 side of the frame allready complete:
Make 2 of those, put em together and you get something like this:
For the moment that is all, making a frame is a lotta work so this part will go slow.
Updates will follow in the startpost!
-==[ Small Update: 03-01-2005 ]==-
Well i made the hdd section in the frame...worked on that for about 3 hours.
It's a bitch to drill the holes, tap wire, make the screws and mount the bars...but...here's the result for today:
And a picture of the connection between the bars:
-==[ Small Update: 04-01-2005 ]==-
I was working on the frontside today, i'm not quite finished but hey..here are the pictures!
(the "hole" is where the plasma ball will come.)
And 1 of the front
-==[ Update: 07-01-2005 ]==-
Well i am allmost finished with the framework now...did a lotta work (allthough it may not seem like it).
Never thought building a frame would take so much time! (and quite a large amount of money)
Anyway, i thought i'd show you guys...soon i'll be sanding the frame down and putting bondo in all the little holes, sanding again..and then paintjob!
well...Pictures say more than words...so let's take a look!
Here's a picture of the connection on the front of the case:
And to give you an impression of where the plasma ball will come...well...here: (i'm still planning on removing the casing on the foot of the plasma ball.)
-==[ Update: 09-01-2005 ]==-
Hey folks...another update...ginished the frame!...used some bondo to fill up the holes and sanded them down:
this is how the holes look without paint:
and this is the result after the primer:
-==[ Update 24-01-2005 ]==-
Well time for a small update again!
I had some time on my hands so i worked on the mobo mounting-tray.
A friend of mine had an old pentium mobo laying around so i used that as a mold (dunno the correct english word) for the mounting tray.
I am not completely finished yet but hey, here are some pictures:
2 pictures of the side:
Picture taken from above:
And 1 from the rear:
I will wait with the plating untill last...since i'm not sure how to solve it yet.
Soon i'll start working on the front, gonna do that with epoxy so i can make it look good with the plasmaball
More pictures of the mobo tray will follow as i'm still working on it!
-==[ Update 20-02-2006 ]==-
Well, i'm working on my case again!
i was outta money and outta time for a while but i have some time again to bring you folks a little update!
I started with working on the front piece, since this part would give shape to the entire case, i made a mold which i filled with polyesther, the result is this:
and
After that i had to shape the front, cut off the edges and stuff, it became a little like this:
After this i was able to make the sides of the case, at first i wanted to do this with aluminium but that was too expensive so i took wood which will be painted black offcourse!
that's it for now, i'm gonna play with bondo later this week
-==[ Specs ]==-
Mobo : Asus P4P800
PSU : 450Watts
No problem!
And 1 of the front
and
