Case Upgrade
KoMiT
I bought the Dell9100 BTX system, if I bought this case CLICK HERE would I be able too swap everything out of the dell case and put it into the new one,
please help!
Yep, it should all fit properly. The only problem, I will see you running in, is that the case doesnt support BTX. But it says it does, so you should be all set. Whats the spec on that Dell? Did you get Dual Core?
Sadly no, im only 14 and I am a freelance designer and I cant afford much, I sold my old dell for 1 grand and I got this one for 1200....
P4 3.0 Duel Core compatible
1.5 gigs of DDR2 ram
Combo drive
160gb hard drive
Ati x300 128mb (going to upgrade to a x800 fanless 256mb)
and It comes with a 2405FPW monitor (main reason I bought this dell and not build my own) :p
so I should be all set! yea!
I cant wait to get this monitor after what I hear about others saying about it on these forums..
not liekly - dell uses customs made motherboards that often dont have the same pin placement to screw in the board as well as special mounted power supplies.
you would need to maybe get an old case and see if the mobo would fit or not.
grr o well, I think I will have to sell this system, (I bought it for the monitor and I was just seeing if I could upgrade it) but I think I will purchase this case anyway, and if it works cool, if it does'nt I will build somthing into it in the near future
