faugusztin
- Mar 9, 2008
For the start, my current case is a modded Lian Li PC-A05, but i want to reuse it for other computer plus i have personal issues with the very thing sheets of aluminium used for this case.
My requirements are pretty much a space for ATX board, space for graphic card with length of HD5870 or a little bit more, space for the Seasonic X-750 PSU, one SSD and a small T-Balancer bigNG. Ideally with internal paint, not just a blank aluminium/steel. The color scheme of my components is black/red (black EVGA P55 SLI board, black/red Dominator GTs, black/red HD5870, red/black Enermax Magma fans, red/black single sleeve cables from FrozenCPU).
Now, what i'm thinking about are these cases :
From these links, you can see i prefer clean, minimalistic cases in terms of design (this removes lot of the cases), and also like them to have small footprint. That is the reason my Lian Li PC-V1110A is in his box unused - because over the time, i realized how superbig that case is for my needs (the only storage drive i use is one SSD and no optical drive, no fan controller in drive bay, so i don't need space for 5 optical drives and 6 HDD
- that removes pretty much the whole Lian Li PC-V line, the Corsair Obsidian 700D/800D, the Temjin TJ07/11, Raven series, Fortress series. I also don't want case with thin panels, that removes the whole Lian Li PC-A/PC-B line, cheap cases etc etc.
Only if PC-X900 wouldn't be nearly 400... For 300, i would buy it instantly, but 100 more is a lot. For that price, i can buy the Define R3 case and one very good SSD at top of it, or make a upgrade to Sandy Bridge without selling my original components.
- Lian Li PC-X900 - my ultimate favorite. Yes, it's nearly 60cm high, but nearly everything else is perfect - size just for a ATX board with some extra space to spare, if i seen correctly then removable bottom HDD rack. The window is something i don't need, but i won't fight against it. Yes, i get some useless space at top because i don't have a DVD drive, but there is no perfect case. Biggest issue is the price - ordering from germany is 335+30 shipping, ordering from my country will cost me 394.
- Lian Li PC-X1000. Pretty much same as PC-X900, except some things i don't like - the 14cm fans, the divider between PSU and motherboard area and the internals are not painted. The price is lower, "only" 352 .
- Fractal Design Define R3 Arctic White - exact opposite of the previous cases, it's white and very cheap, only 107. It uses very thin sheets for panels, but compensates it with dampening material which adds a lot of weight to all panels, so they don't rattle at all.
- Corsair Obsidian 650D - i like the internal layout, the possibility of hard drive rack removal. I dislike the plastic parts and i especially dislike the 20cm fands and the panel mechanism with those things on side panel, as i really like clean side panels (the only exception to this rule are windows). It has no european pricing either, and it comes only in April, so long wait if i decide for this case.
