Case to Motherboard USB Question
Humongous
I have a ASUS A7N8X-E Motherboard in a LIAN LI PC65 case. On the front of the case there are two USB adapters. The connectors (9 single pins) from the case are labelled as follows:
Shield
Data -1
Data +1
Ground 1
VCC 1
Data -2
Data +2
Ground 2
VCC 2
Anyone know how they relate to the USB 56 port so I can connect them right?
Here's a quick tip. Some MBs don't make use of the shield cable coming from the front of the case. So if you run into trouble after making sure all the other connections are correct, try removing that cable (usually pin 9). That one had me stuck for days!
