Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I have an aerogate 2 temp sensor, was wondering where I should put the sensor for getting the entire case temp? I should I put it on top off the otter 5'25 bays (like an inch from the glass panel) ? I have a lian li pc-60b plus
Mine is taped to my PSU and hanging a little bit from it. Haven't had any problems... as to the best place to put it, just do what you think is best I guess.
