Case suggestions please.
Hugger
I want to put together a pc for general home use. Some gaming, photos, music and a little office work.
I'd be using an Asus mobo, E8400 and an ATI 4850 or the equivalent Nvidia card.
I'd like at least 2 120mm fans, front and rear, and a 140 or better top fan in as small a case as I can do this with.
Thanks for any help.
Hugger
How about the Coolermaster 690 or Centurion 590? The Antec 300, 900, and 902 are also good options.
I'd recommend a 590, lots of room, easy to work with and cheap. You would need to buy the 140mm on your own though.
+1 CM 690, +2 if you can find it on sale. Note, I have the NV version so the fans may be different from the default version.
Maybe a Lian Li PC-A17A (or PC-A17B for the black).
Maybe even a SilverStone Fortress FT01.
Both variants come with dual 120s plus a top fan, and they're classy to boot ;)
lol I have the FT01, it has double 180mm fan intakes (top and front) and a 120mm at the back, CPU temps are amazing, gpu temps are decent, and noise is very low considering the cooling. It looks great, but this is not a cheap case
